Thread: Thanks for the Info
    Oct 2007
    Indianapolis, IN
    9
    Thanks for the Info
    We put in our 16x32 vinyl liner pool last August/September, so this is our first full season. I'm using a Taylor K-2006 kit.
    After fighting through my pool being cloudy most of the time the first three weeks it was open, it has now been clear for over a week. I brought my TA down from 200 to 110 using acid and aeration and my CYA up to around 30 or 40 using Trichlor pucks plus more stabilizer in the skimmer. The first few weeks the FC would go from 6 or 7ppm to zero in one day and then cloud up. The last four days, my FC has dropped steadily from where I was shocking (12ppm) without any additional sanitizer and is now at 5.5. I plan on only using the Trichlor pucks now when we are out of town or if my CYA drops. As of last week, I have also started adding 1/2 C. of DE to my sand filter after backwashes.
    My numbers as of this morning:
    FC 6.5 CC <.5 TA 110 CA 320 PH 7.5 CYA 30 to 40
    Thanks again for all the info,
    Mark
    22K gallon vinyl IG, 1 HP Hayward SuperPump, 24" Hayward S244T sand filter, RayPak P-206A-EN-C gas heater, Pentair Rainbow 320 chlorine feeder (only used when away from home), Use BBB method.
    Butterfly's Avatar
    South Carolina
    10,045
    Good job!
    Now can we see a pic?
    You're done SLAMing when:
    Oct 2007
    Indianapolis, IN
    9
    I'll see what I can do...once it stops raining here in the Midwest.
