Thread: Pre-dissolve CYA in warm water?
    Mar 2008
    Nashville, TN - Music City USA
    16
    Hi,
    Does anyone pre-dissolve CYA in warm water before adding to the pool? If yes, how much CYA will 1 gallon dissolve and how long does it take?
    I need to get my pool level of CYA up and I need to clean my cartridge filter, and don't need to wait 1 week for CYA to dissolve.
    TIA,
    Steve
    -ePoolUser Steve
    27'x52" AG, 16,500 gal. Aqua Trol HP SWG,
    2hp pump, 150 sqft 100GPH Cartridge Filter
    TF-100 Test Kit, Zodiac Vac
    Installed July 2006
    CYA takes FOREVER to dissolve. Even in a whole pool it can take a week. I've never tried to dissolve it in water in advance. I can't see any harm in it, but I suspect you'll find it much more difficult to dissolve than you thought. I doubt you can dissolve a decent amount in a gallon.
    Maybe if you have a magnetic stirrer and keep it warm and leave it for a few hours... I don't know though.
    If you try it, post back and let us know how it went.
    Dec 2007
    Central New York
    504
    Go to WalMart and get 3 pairs of socks and use all 6 at one time. Put the CYA in each sock and tie it off by a return and in a skimmer. Squeeze the socks every once in awhile. It takes time.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Guest
    CYA is not significantly more soluable in hot water then cold. Just pour it into your skimmer, run your pump for the first 48 hours, don't clean your filter for a week, and don't stress over it!
    If you have a situation where there is no cya and an algae bloom that is requiring frequent filter cleaning then put the cya in a sock and drop it in the pool but don't squeeze it or put it in the water flow.. You want it to dissolve in the water, not disperse and then get washed out when you clean your filter. It will still take a week to dissolve or possibly more this way.
    Mar 2008
    16
    Thanks Everyone.
    There is a sense of urgency to get it all done now. The other issue I failed to mention is my pressure guage isn't working, so after vac'ing out a lot of debris I'm not sure if my cartridge is clogged or not. So, I've got a new guage to replace, clean the cart and get some CYA in there. Those are just not a convenient set of problems to have.
    The return flow seems strong, so maybe I can wait on the cart clean/guage replace. The CYA issue is the one I'll put on top of the list and wait a week to clean/replace.
    Trying not to stress.
    Steve
    -ePoolUser Steve
    Installed July 2006
