Thread: DIY waterfeature/aerator
    Rockcrawler's Avatar
    El Paso, Texas
    174
    While installing my SWG I was interested in making somekind of fountain/water aerator, here is what I came up with.
    When installing my SWG I had to go ahead a splice into the plumbing after the filter anyways, so while I was there I added a 2" "T" and a Ball valve after the SWG going to the return lines, I reduced the "t" portion 2" to 1/2 and because I have a patio pretty close to my pool and my pool equipment is on the side of the house, I ran 1/2 pvc up and over along my patio, where you would run rain gutter and used some plastic straps to hold the pvc down, put an end cap on the end and drilled 6, 3/8" holes, I can controll the amout of water going through the pvc with the ball valve, in fact if the neighbors behind me want to get cooled off as well it will reach across the yard to them all I have left to do is paint the pvc pipe to match my trim.[img][/img][img][/img][img]cket">[img]<a%20href="http://s301.photobucket.com/albums/nn45/cj7365/?action=view&current=Picture003.jpg"%20target="_blank">[/img]
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Jun 2007
    SF Bay Area
    441
    Rockcrawler,
    Very nice. And the installation looks very clean.
    Thanks for sharing.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Apr 2008
    Central Texas
    326
    Wow, that setup is moving some water!
    I guess that the climate down there is very arid. I noticed the neighbors all have swamp coolers on their roofs.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    El Paso, Texas
    174
    Thanks Titanium
    Harry
    Arid, yes normal humidity is from 10-20% the swamp coolers are very effective economical, when the outside temp is 100 I can cool my house down to 75
