I'm working with a Goldline controller hooked up to a Jandy Auqarite RS system. I set the goldline generator to be remotely controlled by the Aquarite by emulating the Aquapure generator - (AL-5 setting). All lights are on, power, flow, generating... all green. When I put it in shock mode remotely, that light goes on too. I replaced the cell at the end of last season using a generic brand vs. the goldline (perhaps a mistake?). Despite setting the unit to 100%, when I test the chlorine coming directly out of the generator, it isn't reading anything. (pool being kept in balance using tabs and bleach to shock)... numbers below are current but it was at about 1.5 when I tested it. Even with a 2.1, shouldn't I expect the values coming out of the generator to be higher when it is set at 100%?
Temp 80
Saturation Idx -0.5
TDS 4000
CYA 50
Total Chlorine: 2.1
Free Chlorine 2.1
PH: 7.4
Total Alkalinity: 112
Adj Tot Alk: 104
Total Hardness: 103
Minerals 3000
Note 1: I just switched out the PCB of the Jandy to the aqualink IQ 900-RS. Everything appears to be working properly... when i boost the generator from a hand held device the settings on the Goldline controller change.
Note 2: All of the diagnostic data from the goldline generator are within the specs recommended in this forum and the manual.
Temp 80
Saturation Idx -0.5
TDS 4000
CYA 50
Total Chlorine: 2.1
Free Chlorine 2.1
PH: 7.4
Adj Tot Alk: 104
Total Hardness: 103
Minerals 3000
