Time to buy Cl - tabs or bleach?
Jun 19, 2012
8
I've been using a combination of the 1 lb powdered shock bags, and 3" tabs in the skimmer so far this year in our above ground pool. No problems so far. We had been using the Clear Value bleach from Walmart last year....that also worked well.
Now that we're out of the CV bleach, and nearly out of tabs, I was just wondering what the general consensus of you pool experts was. I can get a 50lb bucket of Nava brand 3" tabs from Amazon for $110 shipped, or I can get some generic bleach from Wally World or wherever, for whatever the going rate is. The 3" tabs are certainly more convenient for me, as 50 lbs of 3" tabs will last me a long time, and it saves me the trouble of slogging up to W mart for bleach. However if liquid bleach is that much better, or ends up being that much cheaper I'd go that route.
thanks for any input!
I've been using HTH trichlor tabs, and Clear View calcium hypo shock. I did check out that link (thanks), and it sure does look like liquid bleach is the way to go. Too bad it's so much more of a PITA (to buy, not to use...it's not cheap on Amazon) than the powdered stuff. I guess I'll have the wife stop at WM and pick up some generic extra strength liquid bleach. Thanks for the replies.
I use both. If you understand how each works, then you can balance out your PH/TA/CYA properly each spring/summer. I use Trichlor with some bleach until the CYA is at my desired level. Then I switch completely to bleach. I just bought 4 gallons or a case of 12.75% strength at fleet farm for $9.95. Really cheap so I picked up 8 cases. Keep reading on this site and you too will understand how the chem's work with the different kinds of chlorine. I sometimes use Dichlor too. I have a vinyl pool so I really don't care about the calcium as I am always low.
Just remember to use your test kit and having the knowledge is the key to understanding your pool. You don't have to be a chemist, but just a general understanding goes a long way.
Happy Swims :party:
Whether or not tablets are a good idea in your pool depends entirely on your test results. If CYA has built up to scary levels, tabs are not a good idea. Likewise if pH is low and TA is low, tablets will just make that worse, too.
How big a pool are we talking about? It's not that big a deal to step out back and slop a quart of bleach in once a day.
It's an 18' round, so around 7500 gallons or so IIRC. No, adding the bleach isn't a big deal, it's the trip to walmart and buying it a few times per summer that's the PITA part, at least relative to simply ordering a 2 -3 year supply of tabs from Amazon for $110. I'm in upstate NY, so our swim season is pretty short, maybe early June - late August if we're lucky. I've never checked my CYA level, but so far I've had great luck with just keeping the Cl level up, and running the filter 6 hours/day. This is our 2nd season with this pool.
If you are dumping your water every winter after a short season, you can pretty much do what you want and not get algae if you just maintain Cl. I only switched to BBB after I got a new pool that (IG plaster) that stayed full over the winter. My problems started towards the end of the second season. (My old pool wintered empty and we started fresh every spring. We did cal-hypo for 25 years, then switched to tabs only for the next 30. For most of that time, we didn't even have a test kit.)
I would still recommend keeping a close eye on your total water chemistry and learning what water balance is all about. Just because it "works" with tabs for one season, is no good reason to have excessive free chlorine levels at the start or end up with your pH way too low at the end. Resources are easily available now that we didn't have back in the swimming pool stone age, like reasonably priced test kits and friendly knowledgeable people on the net to help out.
On the other hand, if you keep water in your pool over the winter, you NEED to do those things, or trouble will eventually find you.
It really depends how much water you drain every season and how many times you use their shock products... that will determine how much cya you have in your pool at the start of each season. Cya doesn't get used up over the winter like chlorine will. The only way it gets removed is to remove the water.
It would be a great idea to get yourself a good test kit... Everyone here loves the TF100, you can find info on where to get it in Pool School. If you know where you start with your cya in the spring, you know how long you can maintain a clear pool using pucks. If your cya gets too high, the level of chlorine you add with pucks or shock won't do anything to sanitize your pool.. then you get algae.
Most here use mostly plain bleach because you know exactly what you are adding to your pool, and helps you avoid the problems of cya that is too high. If you are nervous about using "bleach", you can use liquid chlorine from the pool store.
