Thread: Repair or Replace Sand Filter
    Jul 2007
    South Carolina
    8
    I need some advice. I just opened my Hayward sand filter to clean it out and found the center pipe of the lateral assembly busted. I am not sure how but I guess that does not matter at this point.
    What I need advice on is should I repair the sand filter, that is over 14 years old, or should I look for a replacement.
    Thanks
    In South Carolina
    23K IG Vinyl Lined Pool. Pentair D.E. Quad 100
    May 2008
    North Carolina
    79
    We replaced our pump and filter this year. We did both on line for about $600.
    Last year we had our pump repaired to the tune of $200+. In other words, we probably should had replaced it last year.
    I suggest really looking around. I know we got the pump on e-bay cheaper than from the online store - and it was the SAME vendor!
    We got our filter from H2O pool products for about $270. Delivered. I don't know if the repair will be worth it...
    16 X 34 21,000 IG Vinyl Liner
    1 1/2 Hayward SuperPump
    New Sand Filter (had cartridge - hated them)
    If the filter is otherwise fine, no obvious corrosion or other broken parts, and the parts are available, then it is simpler and cheaper to fix it rather than replace it.
    Jul 2007
    South Carolina
    8
    Thanks for the replies. I was not sure of the life of a sand filter so I figured this is the best place to get the answer.
    In South Carolina
