I'm about to pull the trigger on a diy 18x36 vinyl liner with a cozy cove. The cove has 6 jets, the pool will have two returns, main drain and an aqua genie skimmer. After a little research I'm thinking Hayward Tristar 1.5hp two speed pump. It's plumbed for 2". I'm being told 1.5hp is fine but the 2" is needed to supply the volume consumed by the added jets. I'll pipe the cozy cove with it's own ball valve so we can shut them off when not needed. Any opinions? Thanks
