Also, if you are using a 10 ml sample size for the FAS-DPD test, then 0.5 ppm CC is no problem at all since it's <= 0.5 ppm. If you used a 25 ml sample size, you may find that you still only need one FAS reagent drop to clear the sample meaning your CC is actually <= 0.2 ppm or perhaps two drops for <= 0.4 ppm. This is why we say that CC <= 0.5 ppm is not a problem.
