Hayward electric spa heater
riseandrun
47
Good afternoon!
My spa has a Hayward 5KW heater attached and I'm instantly blowing the fuse when I turn the temp. indicator up. I suspect the heater element is bad because I'm only reading 10.3 ohms. Not KOhms.
That seems very low so I suspect a short.
Should add it's 220V.
Any insight would be greatly appreciated. There's not too much to it and my call to Hayward tech support never got answered.
TIA
KW
Hi Bama Rambler,
I see I never sent the reply I thought I did. I was on hold for so long with Hayward that they responded after I sent this post. But here's the new twist: I disconnected the wires to the heating element and turned the heater back on. Everything lit up like it should, I heard the relay click, I measured the voltage at the two disconnected wires (to the element) and got 220? I don't know how, but don't you think it's the element?
