To raise cya or not?
kyle11
May 17, 2012
470
My cya is at 60 right now. Started out at 20 this spring from draining pool water over the winter and have slowly been raising in 3 pounds of cya at a time. My water is perfect right now. Pump run time is as follows with a ecostar pump:
4am-11am 1100 watts
12pm-3pm 1500 watts
4-4:45 2100 watts
5:30-6 3000 watts
My aqua logic is SWG is set at 25% and pool is around 19000 gallons.
Pool gets full sun for 11-12 hours.
Should I add another 3 pounds to bring my cya up to 80? Will I be able to lower my percentage on my SWG if I do?
Thanks
