Results 1 to 19 of 19
Thread: CompuPool Salt Water Chlorine Generator Cell on sale at woot
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    74
    Is this any good.. for $699 ???
    http://www.woot.com
    16,000 G in ground Gunnite (plastered) with attached Spa, Gemini 3 NG Heater, Sta-rite cartridge filter, Aquabot Mark V, TF test kit
    Oct 2007
    Asheville, NC
    43
    I second that question.
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
    Richardson, TX
    287
    About all I can find on the company is they're from Australia, http://www.compupool.com.au/aboutus.html , which my only fear would be US support...but it's a sweet price!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    That particular model appears to be rated for up to 30K gallons. Similar systems typically go for $800 to $900.
    Compu-Pool has no US presence that I can find. It may be tricky to get warranty support and replacement cells in the US.
    Richardson, TX
    287
    The one positive about this is I know Woot is a good company, they're based in the N. Dallas area...but I'd be really uneasy about buying something where I couldn't go back down the street to the store if I had a problem...
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    74
    I found a manual for the darned thing on the australian site.
    http://compupool.com.au/pdf/CPSC%20Owners%20Manual.pdf
    Support might be the only issue.. but the price is very good as per the posts above..
    Feb 2008
    Milford, CT
    340
    Even more interesting is the discussion thread on woot.com about this. Most people have no idea what its for!
    -Chris
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Jan 2008
    Malaysia
    109
    Mine is a Compupool CPSC 24. Introduced by a couple of friends and pool maintenance guy in Australia. They said it's the most reliable one around at that time (late last year). Ran mine for four months before I switched it off to use Cal-Hypo (to get my CH up). No problem so far. Only set back, no salt level reading. System run on 3500 - 4000 ppm salt. Low salt indicator at 2500 ppm and high salt at 5500 ppm.
    8,000 gal IG concrete & tiled lap pool, 1/2 hp pump, 24" sand filter, SWG Auto Clean, whole pool under shed, 3 X 2ft waterfall one end overflow the other end. TF100 Testkit. 80 F Water whole year round.
    Re: CompuPool Salt Water Chlorine Generator Cell on sale at woot
    Did anyone ever try this? Is it any good?
    Well, nobody answered and it was so cheap, I took a chance. The unit is actually very nice. Good construction, not cheap like I expected, and well thought out. Lacks a couple of features the top brands have, like salt content readout, and the ability to operate as a timer for your pump, but if you just want a salt chlorinator, it's a VERY nice unit. I have had an AquaRite before, and this unit is as nice or nicer. Plus, I think it puts out a lot more chlorine than my AquaRite did.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Quote Originally Posted by str8down
    Lacks a couple of features the top brands have, like salt content readout, and the ability to operate as a timer for your pump...
    In the PDF manual(linked in this thread) it says you can set the pump to run two different cycles. Wouldn't that mean that it has the ability to be a timer for the pump?
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Yes. And I was under the impression that it did that too. But notice there are no instructions on how to hook it up. So I called the company, and they said only their aboveground units have that feature. Why? I have no idea.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    That doesn't make sense. You'd think if anything the IG units would have it as they are usually more advanced then AG stuff.
    Weird,
    Adam
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I don't know if it's a code issue or what, but every dedicated AG unit I've seen has an outlet for the pump. I don't know why they assume one outlet or pump control for AG pools, but that seems to be the case.
    I bet it is a code issue. I also bet, that if I knew where to hook up the pump, it would in fact operate it. I just don't know where to hook it up.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I asked a guy at NSF and he was non-specific except to say that:
    NSF 50 does require the electrolytic chlorinators to have an automatic
    shut off mechanism for shutting off the electric power to the
    electrolytic cell if there is a loss of electric power to the
    recirculation pump or if there is interruption of water flow through the
    electrolytic cell.
    Notice it says power OR water flow, so for cells like Goldline and Jandy use that require separate flow switch installations (which can't be installed on standard AG filter hoses), the pump shut off is more practical for the manufacturer. It ensures that the cell gets power only if the pump has power, thus negating the 'need' for a flow switch. They also require (in my experience) that these units be mounted vertically so that in the event of a loss of water flow the gas can escape.
    I may open it up and hit it with a multimeter this weekend and see if the contacts to operate a pump do exist. I know there are numerous contacts inside of it.
    Jan 2008
    Malaysia
    109
    Which model is yours? Mine comes with a pump outlet socket and pump control timer for 2 cycles per day.
    The big one. The 3600 or whatever. The one for 40k gal pools.
