Test results-please recommend
mjt123
Jul 5, 2007
29
Here are my numbers after replacing about 30% of the water. I have a gunnite bottom and fiberglass walls that have been coated with epoxy paint. Approx. 24000 gallons, sand filter.
Free chlorine: 4
Combined chlorine: <.5
PH: 7.4
alkalinity: 100
CYA: 35 (was 80)
hardness: 90
temp: 75
I believe I need to bring up my alkality and hardness. If so, what should my goal be and is there a non-pool store product that I can do this with?
Please make any recommendations you see fit.
Thank you so much,
Mike
Those numbers look good to me!
Your alkalinity (TA) is fine where it is. And there is no reason to bring the CH level up (unless you have a spa you forgot to mention).
Remember to keep FC around 3 to 7 and never below 3.
