Fix-a-Leak Products
I would only try Fix-a-Leak if you have no other options of any kind. Fix-a-Leak can work, but it often doesn't. More importantly, it only has any hope of working on pressure side leaks. Another major thing to remember is that it will destroy the filter if you don't bypass the filter, and can clog other small openings (ie never run it through a fountain or sprayer or anything similar).
