Thread: Tips for setting up a propane contract?
    Mar 2008
    Lafayette, LA
    108
    I need to get set up with a propane supplier so that I can make use of my spa. Can I get some tips on what kind of deal to shoot for? I think there are several options when purchasing, ranging from prepays to buyuing tanks vs. renting, etc? What do you guys do?
    7x7 spa drains>16K IG, Gunite/Plaster, Compool 3600, Purex Triton Minimax Plus 350, Sand Filter, 8 Gal Liquidator
    Aug 2007
    Northeastern Ohio
    178
    I don't use propane to heat my pool, but I do have a 500 gal tank on my property for my house heat and hot water tank. The tank was here when I bought the house, so I stayed with the supplier the previous owner used. The tank says "property of Amerigas" right on it, so I'm assuming it's leased (that discussion never came up with Amerigas, surprisingly).
    I've been pretty happy with Amerigas, so if they service your area, I would give them a call. They'll give you your options and prices.
    One thing I can recommend: DON'T go with the "lock-in" rate. In the fall, they offered to "lock-in" a rate of $2.19/gal for one year. Even with the crazy price of oil right now, I'm still only paying $1.79/gal (I usually get about 300gal per fillup).
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    A 2.19 lock in would have been great in SC. We're at 3.40 gallon
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Mar 2008
    Lafayette, LA
    108
    Thanks, I do have an Amerigas supplier around here. I guess I need to see if I can't research the price trend for the last year or so around here to see if the "lock" is worth it.
    Thanks for the tip, that was exactly what I was looking for.
