New water
Bryan
May 31, 2008
29
Tarpon Springs, FL
Hello all! I've been reading all of the posts on this forum and I think I will try the BBB method this year. I put in a new liner and filled the pool yesterday. I haven't been able to find any past posts about starting up using the BBB way with fresh water. Do I need to bring the chlorine up to shock level, or just up to 2ppm? So far all I have done is put in 3 lbs of stabilizer and 2 lbs baking soda (TA checked at 80). Thanks for any advice!
No need to shock fresh water. Just bring your FC up the the proper level for the amount of CYA you added. Use Jason's calculator.
Also, check your pH and get that adjusted soon. With the addition of the soda, you may have raised the pH a bit...
Welcome to TFP!
