Thread: do I ever have to shock?
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    I was told at a pool store that everyone has to shock their pool about once a week in the summer. Is this true? I thought that I read somewhere that if you keep your water balanced that you do not have to do this. I have the TF-100 test kit and my chlorine is always good. I have never had any CC's. My free chlorine is always what my TC is. Now, according to test strips that I have purchased, my free chlroine is 0. I am relying on my TF-100 test kit though. My water stays crystal clear, so that works for me. I was really wondering if I need to have shock on hand.
    17,000 gallon roman shaped gunite pool-AquaRite goldline SWG
    Baton Rouge, LA
    237
    If you sold chemicals to people who don't know what they're doing, wouldn't you suggest that they SHOCK every week?
    "... and our SHOCK is ON SALE this week... you should stokc up before we run out..."
    just got our pool last year, we didn't "shock" it until this spring when I let the sun sneek up on me and had a lil algae infestation... pretty sure that's the only time you need to "shock"... if you're diligent... maybe never.
    I'm sure somebody more smarts than me will chime in.
    The more I know, the more I might open a pool store...
    as Back-Flip Wilson would say...SHOCK IT TO ME!! SHOCK IT TO ME, BABY !!!
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    Jun 2007
    SF Bay Area
    441
    teppy,
    I have never shocked my pool except for this spring when I inadvertently let an algae bloom get out of hand.
    I also want to open a pool store.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Ohio
    217
    teppy... I shock in the spring and about a week before I close the pool. As long as your CC is at .5 or below there is no need to shock as a maintenance procedure.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Butterfly's Avatar
    South Carolina
    10,045
    teppy, I agree with them!
    Most of us RARELY need to shock.
    A great test kit, like the TF 100 that you have and water maintenance is all you need to avoid shocking!
    5 minutes a day and beautiful water!
    Look at all the $$$ saved by not being pool stored!
    You're done SLAMing when:
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    thanks for the replies! I was sure that I read that shocking may never be necessary as long as the water is maintained properly. I think I will open a pool store too. stephenbrla, I'm from baton rouge. I live in pointe coupee now.
