Thread: Pent Aire Dynamo pool pump/filter And Aqua Illluminator
    Please help!It seems like the Aqua illuminator light is interfering with my pool pumps water pressure?What can I do??THANKs ALLOT!!!!!!!
    23,000 gal grecian vinyl IG with cover
    Jun 2007
    SF Bay Area
    441
    LadyLora,
    Welcome to the TFP forum!
    Please post your pool details and equipment details in your signature. Here is a link detailing the kind of information that we find useful in helping you. http://www.troublefreepool.com/sticky.php?s=3662
    What symptoms are you seeing that lead you to think your light in interfering with your pump pressure?
    What does your water look like? Clear and sparkling? Green and cloudy? Other??
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Well,it is a 24ft round above ground which is 30,000 gallons??I have a pent aire dynamo filter..and where the water shoots across the pool there is a light and it seems to have hardly any pressure and I am thinking it is because of this light and optional water sprinkler..My pools is currently a swamp.Just toke the cover off! Lots of work ahead of me!Thanks for the response!!!
    Jun 2007
    SF Bay Area
    441
    LadyLora,
    Have you cleaned your filter recently? What is your normal filter pressure in psi, and what is the filter pressure when the filter needs cleaning? What is the filter pressure right now?
    If your pool is a swamp, you have an algae bloom. Lots of fun. Read this sticky and then ask questions. http://www.troublefreepool.com/sticky.php?s=4147
    If you don't already have a decent drops-based test kit, you are going to need one. A TFP member sells such a kit, and Taylor has a kit as well as Leslie's Pool.
    Titanium
