weird_tolkienish_f said:
257WbyMag said:
Did it just start sounding loud or has it always been this way?
I didn't notice it in 2011, in 2012 I noticed it was loud and now it seems to be whining. I'm reading online that it could be bearings or just old.
It's a Hayward pump.
Just wondering what options do I have?
Post a youtube video of it running, see what the pros think.
The good news is, if it's just the motor, you don't need to cut pipes. I changed my dead motor in place.
Here goes:
noisy filter
Sounds as if the bearings are worn out. Are you getting good pressure out of your return lines? I would check to be sure it is pumping water effectively. If it is the bearings, they are replaceable and inexpensive if you are a DIY'er.
Update. I will be replacing the pump and multiport valve at the end of this season. The thing is that there is a leak on my multiport valve, and it corroded the pump housing. At this point I think it's just easier to replace the entire pump.
Look around well because they sell for different prices for the same pump. As for the multiport, there is a replaceable gasket under the top. Pop out the screws and replace the gasket, they are cheap.
