Thread: New and another one from SE Michigan
    May 2008
    Fort Gratiot MI
    66
    Hi everyone,
    Just joined and man what a site!! This place has days full of info to read!! Thanks to all that contribute so anyone like me can have and maintain a pool.
    Just had a 24 ft round Doughboy installed a few days ago. Had the intex soft side for a few years and figured we used it enough to get the real thing. It is the Desert Spring model with a Silica II filter and a 1hp doughboy pump( paid 3180.00 out the door) and a 180,000 btu Raypak heater, got the heater for cheap too ($450.00 used 3 yrs) and I figured it was overkill but the pool will be hot!. (Side note will it be ok to bury some spaflex tubing to run the heater over to the pool? It will be about 15 ft each way)
    Ordered a TF100 also cant wait till it gets here.
    Today I went to 2 different pool supplies with the same bottle of test water, they were both almost opposite of each other as to what to sell me chemicals to add to the pool!! LOL So the test kit will be needed for sure!
    Also I forgot in my original post I have a Sundance Optima spa. Ive had it for about 5 years now.
    Thanks
    Brian
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    May 2008
    SE Michigan
    38
    Welcome fixit5561. SE Michigan is multiplying like crazy. You're going to learn a lot here, as I am. Read,read,read, there's so much good information here.
    Skinman
    16 x 32 Doughboy AGP
    Doughboy 17" AquaView sand filter
    1 HP, 2 Spd. pump
    (4) 2 x 20 Sunheater Solar Heat
    Solar cover w/reel
    TF 100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Brian and welcome to the forum!
    Sounds like you got a deal on a pool!
    You are already way ahead having ordered your TF Test Kit! Congrats!
    Sooooo glad you already know about the pool store testing
    We're glad to have you!
    You're done SLAMing when:
    May 2008
    Fort Gratiot MI
    66
    Thanks for the welcome. I hope to learn alot here and also be able to help if I can.
    I already have spent about 10 hrs reading and learning already, this place is great!!!
    Brian
    BBB method
