Thread: Aquabot Turbo T2 Vacuum
    This automatic cleaner consistently gets stuck on the suction line at the bottom of my pool. Just the perfect size to get stuck and not be able to free itself. Anyone else have this problem? anything that can be added to the vacuum? or maybe making the cap on the suction line a little larger?? not sure about this just wondering
    thanks
    39K IGP Vinyl free Form SWG, 2spd motor, 4-cartridge filter
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Is it getting stuck on the main drain? Can you shut off the MD and run on skimmer only when the cleaner is in the pool?
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Actually i do turn off the main drain and go full skimmer. I had a 2nd line also at the bottom of the pool just in case i needed a 2nd one for a waterfall tha i have. I never did install and it always gets stuck there also. It seems to be the perfect size to fit between the tracks of the vacuum and it's widest point (main drain cover) the vacuum gets stuck. Put it on for 2 hrs....go out 1/2 hr later to check on it and it sitting there stuck....Do they make a "wider"version of the main drain cover of just some sort of guard?
    thanks
    tom
    Anyone have any experience with the Polaris UniCover? Seems like that helps protect the vacuum from getting stuck
