Each pump uses a different wet end from another pump line
Sp2300vsp- Uses the Maxflo wet end - Targeting AG pools
Sp2600vsp - Uses the Superpump wet end - Targeting small IG pools with small plumbing
Sp3400vsp - Uses the Tristar wet end - High efficiency pump targeting higher flow rate applications
Sp3400vspvr - Same as above but with a vacuum release safety system - Targeting spa applications
What is your application? Please fill out your signature with your equipment.
The SP2600vsp would be closest to what you have now and you could possible use the same wet end so you wouldn't need to do any plumbing work.
What do you pay for electricity and why are you looking a VS pumps?
Electricity is pretty high on Long Island NY
I'm paying a little more than .09 a KWH
Was looking for variable speed for energy efficiency
And I was putting in a geyser effect in the deep end so I can control
The amount of pressure for that effect and the hot tub jets
Strange that they have it listed only under "In ground pools" section of there website...and the price which is comparatively high to other AG options.
Looks like this one might be obsolete now?
The MaxFlo II series is an in ground pump. The Power-Flo series are the AG pumps. Hayward has discontinued the sale of the MaxFlo non-VS pumps but you can still find them on the internet.
http://www.hayward-pool.com/prd/In-Grou ... 3502_I.htm
The SP3400 series is the EcoStar and they are still selling those.
I'm totally confused. I just installed a sp2300vsp... Your first post indicates it's for ag pools?...
It appears to be working well... What should I be looking at... I run a kreepy great white and a liquidator... Pool in sig
