Results 1 to 10 of 10
Thread: R-0871 drops
    R-0871 drops
    Hi,
    I bought a Taylor FAS-DPD test kit last week and I was testing the chlorine. I put two dippers of the DPD powder
    and the water turned reddish. Afterwards, I added the R-0871 reagent drop by drop. I counted 30 drops before
    I stopped. The solution still did not turn clear yet. Is this normal? Am I doing something wrong? thanks in advance.
    That is normal if your chlorine level is higher than 15.
    Ohio
    217
    rainman...the test worked right turning pink after that not. it is possible you grabbed the 0003 instead of the 0871. they both have yellow caps and by your results is what it will do. (ask me how I know ) try again if it you get the same result replace the 0871 or contact tayler if you think your cl is below 15.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Thanks for replying so quickly. Usually, how many drops do you usually use before the solution turns clear?
    The number of drops depends on what your free chlorine level is. I have had anywhere from 1 drop to over 100 drops depending on what FC level I was testing. Having a normal number would only happen if you maintain a uniform chlorine level.
    My TA is high (260).. so it took me 25+ drops.
    Also, don't let the quick "turn to pink" fool you. The water should stay pink before you stop adding drops.
    2003 Marquis Euphoria - 400gal
    Do you guys put in two dippers or one? I have been using only one since it will turn the 25 ml sample pink. Should I be using two?
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    As long as the sample turns pink you are good. Usually one scoop will do it, but sometimes it takes two.
    Mar 2008
    Central VA
    328
    Duraleigh's kit says "one heaping" scoop, and that has worked great for me. His uses R-0871 also.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    I am just using one heaping scoop
