Thread: old brittle leaking return eye leaking
    Dec 2007
    Griffith, in.
    3
    I was trying to tighten the return eye, and then it cracked. I new i would need to replace it, it looks a bit sad. My question is. (i know it is obviouse) I just need to ask. can/is it possible to replace this w/o draining below the return? and what else is needed for the repair, gaskets, sealer etc. TKS!!!!!!!!!!!!!!!!!!!!!!1
    rgomez
    griffith, in.
    ag 24' round
    13,5??? gal.
    hayward sandfilter 250#
    pump unknown
    It depends on which part cracked, part of the eyeball fitting or the return fitting. The eyeball has three parts, the eyeball, the cover, and a sleeve that screws into the return fitting. It is fairly easy to replace any part of the eyeball fitting.
    I just replaced the whole assembly on my pool. I bought a winterizing plug for the return for $3. I had my wife hold rags over the holes to minimize water loss as I removed the old return. The plug stopped water from coming out of the new return until I had everything hooked up. I think we lost a total of 5 gallon of water, so not much at all. JUst make sure you have some one to help you. The whole process took about 2 minutes.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    Dec 2007
    Griffith, in.
    3
    i ended up draining the pool past the returnand the swap was quite simple. Tanks for the replies.
    rgomez
    griffith, in.
    ag 24' round
    13,5??? gal.
    pump unknown
