Boiling water in pool pump
stevex
Oct 4, 2009
9
Yeah I figured that subject would get your attention.
I uncovered the pool a couple days ago and fired up the pump. Everything seemed fine - enough suction to run the pool cleaner.
Today I went to check on the pump and I see there's no water moving. One of the knobs that holds the basket lid closed is not on - I think someone must have cleaned the leaves out and not screwed them both on, and I guess what happened is the pump ran all day with no water moving.
There was a bit of water in the pump basket and it was darn near (or perhaps actually) boiling. Even an hour later the water is too hot to stick my hand in. I guess the whole inside of the thing heated up quite a bit running dry all day.
So, now what. I don't know if this has seriously damaged the thing, or if I can just seal it back up, turn it on, and expect it to be fine.
The motor still runs, and it sounds okay .. but I didn't let it run long enough to prime. (It always seems to take a long time to prime - many minutes - don't know how normal that is).
Thanks
-- Steve
Has the hot water distorted the filter basket or the lid so that it will not seal? If not you may be OK. I had a similar experience with my previous pool.
Well this sounds promising.
The PVC heading up to the sand filter was a bit less stiff than usual but nothing looked melted. The filter basket is okay. So maybe I got lucky. Guess I'll find out tomorrow.
If it won't prime tomorrow - what then? Is this a repair or a replace?
