Hayward Vari-Flo Valve Gasket Replacement question?
May 17, 2009
95
NC
Should I use some sealant to glue this gasket in place or nothing at all, simply install the gasket on the cleaned-up plastic? If it requires adhesive what should I use?
After the gasket has been replaced, should I lube it? If so what should I lube it with?
Thanks!
Thanks Bama, it was glued in on my old valve. I replaced the valve last summer, and the gasket has failed, this new one is not glued in. I just redid my pool walls, in addition to a new liner. I am in the process of re plumbing my pump/filter deck, and I am lowering the chlorinater below the valve. Plus I am going to use the BBB method strictly, going forward, so I am hoping the new gasket lasts longer. Thanks again!
