Results 1 to 10 of 10
Thread: Fired the Pool Service Company
    May 2008
    SE Texas
    18
    I was at home on Monday when the pool man showed up. I asked him to leave the SWG alone. (I have it turned off because my FC has been around 22). He wanted to know why so I told him and he proceeded to test the chlorine. He filled a test cylinder with pool water and put in something pink - I thought to test for Chlorine the water would be yellow -and he told me my chlorine level was just right at 1.5. I have no idea what he was talking about but I mentioned again to him about my FC being so high and he then told me he didn't have any idea what FC was "but my chlorine level was perfect".
    Anyway, he's gone.
    This is where I was 10 days ago:
    FC 22
    pH 7.2
    T/A 80
    CH 410
    CYA 40 (was down to 30 within few days)
    Here are my new test numbers as of today.
    FC 6
    pH 7.5
    T/A 60
    CH did not test
    CYA 70
    I put in stablizier last Friday and added acid on Monday, other than that all I've done is leave the SWG off.
    Oh, and I added about 8oz of baking soda (all I had) because I thought my T/A was dropping too low.
    It rained A LOT here last night, I've read that this effects the water but how?
    18x36 Gunite w/7' spa, Whisper Flow 2HP Pump FNS DE 60 sq.ft Filter, Letro Jet Vac, Minimax Heater 400,000 BTU, Goldline Aquarite
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Good for you for firing the pool company! I haven't a clue what he was testing for if it was pink- other than the stuff we use to test the TA
    Everything looks pretty good, but the TA you want to bring up a tad to about 80-110ppm. To low of a TA then you risk corrison, to high and you get that cloudy water.
    If your TA is at the proper level, then your pH is less likely to bounce all over the place as well.
    And likewise, If you have acid rain or a lot of rain in general that is usually what will affect your TA the most, which in turn affects your pH. So it's better to have mild flucuations by testing at least CL and pH daily than having something sneak up on you.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Jul 2007
    Waterford Michigan
    36
    It is passable that he was testing for Cl2. I work in the drinking water industry and the HACH test kits we use to test for free and total does turn the samples pink. But I can't understand how he did not know what free Cl2 is.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    May 2008
    SE Texas
    18
    Thanks Lulu.
    The Pool Calculator says to at 136 oz of baking soda to raise my T/A. Should I add this all at once?
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by plumin
    Thanks Lulu.
    I would add about half, wait a few hours and retest to make sure you don't send your pH soaring above 7.8 (adjusting TA also raises your pH)
    *~ Laura ~*
    TF-100 Test Kit
    TA around 70 or 80 is fine. There isn't any need to raise it above that with a SWG. You need much higher TA when you are using trichlor tablets.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    The OTO chlorine test uses varying shades of yellow to brown to indicate the level of chlorine, and the DPD Colorimetic test uses varying shades of pink to indicate the level of chlorine.
    Here's a link that describes OTO, DPD, and FAS-DPD tests pretty well. linky
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Butterfly's Avatar
    South Carolina
    10,045
    Hi plumin and welcome to the forum.
    Here is a sticky on "Water balance tips for a swg" by waterbear: http://www.troublefreepool.com/sticky.php?s=3663
    And, as Jason said, your TA around 70 or 80 is fine, in fact preferable.
    You're done SLAMing when:
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    If you don't mind me asking, what test kit are you using for your readings?
    May 2008
    SE Texas
    18
    ohmboy - I'm using the TF Test Kit.
