Results 1 to 11 of 11
Thread: Vaccumming clouds pool with dirt being vaccummed
    My pool water is very clear but I have a lot of dirt on the bottom of the pool that I don't seem to be able to vac out of the pool. When I vac it, the dirt disappears but I can see the return jets bringing non-clear water back into the pool. When I have finished, my clear water has turned cloudy and will stay that way for about a day. It seems as if the dirt is being recycled back into the pool and then settles back down to the bottom again and the sand filter is not trapping the dirt. This is the 3rd season for this Hayward filter. I had the same problem last year. I tried new sand at the beginning of last seaon but that did not help. I also added a SWG last season along with a new liner, and new city water. I get a tremendous amount of scale build up on the SWG cell. I have tried sweeping the pool on waste but still can't get rid of all of the dirt. Seems like a filter problem, but all I can think of is new sand again. Any suggestions?
    10,000 IG vinyl liner pool, Hayward sand filter, Hayward SuperPump (converted to 2-speed), BBB user
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Is there any possibility that the lever on the filter has slipped to 'recirculate' rather than be set on 'filter' or 'waste' when you vacuum? That would blow dirt back into the pool.
    Another cause could be a leaky gasket in the filter which lets sand out through the return. I'm afraid I can't remember whether this is called the 'spider valve' or the 'lateral' or something else entirely. We had to replace ours last year because we were getting sand and dirt back in the pool.
    Can't help with the scale buildup, I don't know anything about SWGs.
    AnnaK
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    If you post a full set of water test results we should be able to figure out what is going on with the scale buildup on the SWG.
    I've had a very similar problem since our pool was installed 2 years ago and thru experience have found that the debris I am dealing with (not sure if it is dead algae, pollen, or some other sediment) will not filter out thru my sand filter. To eliminate it completely I used to have to vacuum to waste very carefully b/c any movement would cause the debris to lift off the bottom and cloud the water. The stuff I have is very light and very fine. I've since rigged up a venturi vacuum with a bag called a Slimebag that will capture these particles without draining water out of the pool to waste.
    7900 gal Delair AG, 14" (not for long!)Doughboy Sand Filter filled w/zeosand, 1.5HP Doughboy (not for long!)pump, avid BBB disciple converted from baquacil
    JasonLion,
    Here are the water test results from today ref the SWG scale problem.
    CYA 29
    Tot Chlorine 2.2
    Free Chlorine 2.2
    PH 8.4
    Tot Alkalinity 178
    Tot Hardness 286
    Minerals 2800
    Borates 9
    THX...Paul
    Sandy A,
    What is a venturi vaccuum and where can I buy one? If you made it, could you send me pictures and instructions on how to make one?
    THX....Paul
    You need to get your PH down! You should always keep PH between 7.2 and 7.8. High PH will almost always lead to scaling.
    Phess,
    I also replied to your PM but thought I'd put the info here in case anyone was interested.
    I purchased the venturi vacuum attachment at Home Depot a couple years ago but I am unable to find the same one online to direct you to it. I did however find this one that is somewhat similar
    http://www.poolshop.com.au/category78_1.htm
    I just spoke with the Slimebag representative today because I am considering purchasing a Slimebag to install on my return line. I have to vacuum this stuff up almost every day throughout the summer and with my contraption it is somewhat tedious. While speaking with him, he said that he believed the debris I described may be dead algae that is being broken up into even smaller particles while passing thru the the filter due to the brittleness (is that a word? LOL) of the dead organisms. I've never heard anything similar mentioned anywhere, even on this site so can't vouch for the accuracy, but thought it rather plausible just the same esp. since I have an oversized pump that I believe is causing a lot of my filtering problems (I'm researching smaller ones even as I type).
    If you need any more info re:the venturi vacuum attachment, please don't hesitate to ask.
    Sandy
    Feb 2008
    Milford, CT
    340
    Have you tried reserving vacuuming until your filter is on the verge of needing a backwash?
    Needing backwash means a dirty filter, and a dirty sand filter filters better than a clean one. It might catch this stuff before it makes it back out to the pool.
    -Chris
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by phess
    JasonLion,
    CYA 29
    Tot Chlorine 2.2
    Free Chlorine 2.2
    PH 8.4
    Tot Alkalinity 178
    Tot Hardness 286
    Minerals 2800
    Borates 9
    THX...Paul
    Hi Paul and welcome to the forum.
    Your CYA is too low for a SWG and your ALK is too high.
    Here is “Water Balance Tips for a SWG” by Waterbear: http://www.troublefreepool.com/sticky.php?s=3663
    Hope this helps
    You're done SLAMing when:
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    Re: Vaccumming clouds pool with dirt being vaccummed
    Sounds like an undersized filter. I had a Hayward sand filter for an 18 ft ag and when I vacuumed the pool, everything would be going along just well, and then dirt would start coming back into the pool. I would have to stop and backwash the filter. I've since switched to a cartridge filter.
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
