I'm putting in an oval 15 x 30 "on-ground" pool that will be sunk in the ground.
Having trouble deciding on where exactly to put it...
My lot is very narrow, and there won't be a lot of privacy (new subdivision). Currently there is nothing except a floating wood deck (I might remove it and add a covered deck attached to house). We will be fencing in the pool (that's a fence on the drawing, not decking). Should i keep the equipment at the back of the lot (to reduce noise near the patio?). I left a bit of room between patio and fence of pool for a small firepit area, is that a bad idea? Does the pool seem too separate from the seating area? We live in Canada, so there will be times when we want the kids to be able to be on deck etc without being able to get into the pool.
