Thread: Refills?
    Taylorsville, MD
    35
    Refills?
    are there refills or will there be refills soon?
    I have one of Ben's PS233 kits and just need refills on a few items.
    or perhaps since the whole kit is a few years old, maybe I should just order a new kit?
    thanks!
    -mark-
    Using BBB successfully for over 5 years!
    16x32 vinyl grecian, Hayward EC65, 1hp super pump, Clear solar cover, Loop-lok winter cover, "The Pool Cleaner" 2 wheel suction cleaner
    Over at the Pool Forum there is a cross reference of the Taylor reagents you can order to replace the ones in Ben's kit.
    Conventional wisdom on the life span of reagents varies from one to three years. Though some of them clearly last longer than that, there doesn't seem to be any good list of which are stable and which are not. If it has been a couple of years I would just replace the whole thing.
    Dave was working hard to get the kits together, and will be working on refills at some point in the future. Probably, if you needed enough refills at once, you might be better off cost-wise to get an entire new kit. By the time you need refills again, like in a couple years, I am sure Dave will be ready-freddy!
    However, he will add more info or correct anything I got wrong!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Taylorsville, MD
    35
    actually, Dave emailed me back pretty quickly (and on a Saturday no less!)
    he said he was working on the refill kits and would have them soon...
    in other news, I was reading on the Taylor website the shelf life of most chems is one year...mine is at least 3 maybe even older...guess I'll just order a entire new kit.
    in even more news, my local Namco has a new product out called "Econo-shock" for $3/gallon...guess what it is?
    thanks for the quick replies
    ktdave's Avatar
    Katy, TX
    888
    BLEACH!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
