Results 1 to 8 of 8
Thread: P1102FE 24-hour Electronic Time Switch - 240V
    Thoughts on this timer?
    My goal is to simply run the pump four hours in the morn and four hours in the evening.
    2003 Marquis Euphoria - 400gal
    Nearly all of the Intermatic timers are quite good. That one should be fine. There are various other models with a variety of additional features. The P1102FE is a good basic model.
    Great. Good thing my father-in-law is an electrician.. I am curious if my current wiring is standard or common..
    One switch to power on filter pump and heater (electronic). On that same power feed I have another inline switch that toggles power for the booster pump.
    Apr 2008
    Central Texas
    326
    To keep everything in sync, something like the T30401R shown here: http://www.poolcenter.com/timers_automation.htm will do the job.
    I have a similar unit, but mine also includes freeze protection which turns on the main pump when the temps get too cold. We don't have to winterize the pool here, as the temp rarely drops below freezing. Running the pump when the temp drops keeps the pipes, filter, and pump housing from freezing.
    I run my main pump twice each day, but only run my Polaris during the morning run. I have the timers set so that the Polaris comes on 60 minutes after the main pump and shuts off 60 minutes before the main pump.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    ^^ thanks. I didn't want to spend quite that much. And I plan to just run the Polaris manually.
    Jun 2007
    SF Bay Area
    441
    jjdurrant,
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Ha. By manually I mean on\off toggle switch with my booster pump. :P
    Jun 2007
    SF Bay Area
    441
    jjdurrant,
    I think I was misinterpreted.
    What I meant was that it would be useful to see pictures of the pool, pictures of your existing electrical system to the pool, etc.
    Titanium
