Thread: Stenner acid tank/pump
    Apr 2008
    Burlington, WI
    67
    Those of you who have an acid pump with the Autopilot TC, do you put straight muratic acid in the tank or do you dilute it?
    Thanks, Jeff
    58,800 gal gunite INDOOR pool w/ spa
    automatic cover
    Jandy "stuff" - pumps, cartridge filter, aqua link
    CAT Controller 4000
    Stenner 30 gal (bleach) and 15 gal (acid)
    Puck chlorinator and Nature 2- gone
    Hi-Z Heater - natural gas
    AutoPilot suggests a four to one dilution (water to acid).
    Apr 2008
    Burlington, WI
    67
    Any ideas for this recommendation? I don't have the Autopilot...yet. I have a 2-stenner tanks (one bleach and one acid). I'm guessing I will follow the Autopilot recommendation.
    automatic cover
    CAT Controller 4000
    You do want some dilution, both to prevent fumes from being an issue and to keep the water in the pipe from having too low of a PH when the pump is injecting acid. The counterpoint is that the higher the dilution the less acid you can fit in the tank.
    I expect that anything from 3 to 1 up through 6 to 1 would be fairly reasonable, though it depends somewhat on the rate at which the pump injects acid.
    Apr 2008
    Burlington, WI
    67
    That makes perfect sense. Thanks. My pump range is 0.2 to 5 GPD. So any dilution should work.
    automatic cover
    CAT Controller 4000
