Thread: Liner sag from coping
    Fayetteville, Arkansas
    220
    Anybody know of a safe way to reattach, lift up or otherwise slip the liner top edge back into the coping? I have two or three the worst being about 6 inches with the sag about 1/2 inch. Sure don't want to tear the liner. Your experiences with this little problem?
    20x40 30,000 gal IG Liner, Pentair II Sand
    Jan 2008
    Burbank, IL
    109
    Is it an IG, AG, overlap, j-hook, etc... I would like to try and help but I need more info about your pool.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    220
    Quote Originally Posted by mnormington
    IG . . . sorta like a tongue (liner) and groove (coping strip).
    Liner edge slips into the coping and catches. Don't know the official terms as you can see.
    Thanks for any help you can offer.
    use very hot water pour it on the liner and than try pulling it up
    220
    Quote Originally Posted by all your parts
    That sounds reasonable enough ... thanks.
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    89
    Re: Liner sag from coping
    Seven years ago, no reply. Musta worked. I need to do the same thing to mine, so I will try the hot water trick too.
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Autopilot Digital Pool Pilot
    Town water
