Results 1 to 7 of 7
Thread: Borax Source
    Stony Lake, Michigan
    10
    Borax Source
    I have access to unlimited supplies of the sprayable agricultural boron product called SOLUBOR. The label says this is Disodium Octoborate Tetrahydrate. I realize 20 mule team is relatively inexpensive but am curious if this SOLUBOR could be used in pool maintenance. The URL of the data sheet is http://www.borax.com/agriculture/files/ ... olubor.pdf
    "It's All About The Duck"!
    Mar 2007
    San Rafael, CA USA
    12,082
    Unlike 20 Mule Team Borax which is Sodium tetraborate decahydrate or Proteam Supreme which is Sodium tetraborate pentahydrate, the chemical you are referring to is octoborate and is NOT the same and furthermore does not dissolve in water in the same way. It appears to stay as octoborate rather than forming boric acid and can form super-saturated solutions. Borax does the following:
    Na2B4O7•10H2O --> 2Na+ + 4B(OH)3 + 2OH- + 3H2O
    Borax --> Sodium Ion + Boric Acid + Hydroxyl Ion + Water
    Unless someone can find something that says that Disodium Octoborate Tetrahydrate (DOT) dissolves in water to form boric acid, then I would not use this. We do not know what DOT does except that it is a pesticide. It probably does not act as a pH buffer. My guess is that it does the following, and this is truly a guess:
    Na2B8O13•4H2O --> 2Na+ + B8O132- + 4H2O
    DOT --> Sodium Ion + Octaborate Ion + Water
    Richard
    10
    I thank you for your help!
    Mar 2007
    San Rafael, CA USA
    12,082
    According to this MSDS, it appears that Disodium Octaborate Tetrahydrate may in fact dissolve in water to form primarily boric acid that is the same as what Borax would do. However, I cannot be certain of this as some other sources seemed to imply a different solubility (not just by weight). Sorry I can't help more about this. Probably better to play it safe and not use it unless you get firm confirmation that it produces boric acid in water.
    So it might do the following:
    Na2B8O13•4H2O + 9H2O --> 2Na+ + 8B(OH)3 + 2OH-
    DOT + Water --> Sodium Ion + Boric Acid + Hydroxyl Ion
    Richard
    10
    US Borax seems to be pretty tight lipped about their products. Probably why you can't get generic Borax at Wally World
    Feb 2008
    Sonoma, CA
    2
    Solubor vs ordinary borax
    Being unable to find 20MuleTeamBorax in my area, I went to the ag store and purchased Solubor. Then I read this post.
    Hmmm. I called U.S. Borax, Tel: (1) 661 287 5400, and asked if the products were equivalent in action. I was assured that they were. If I understood the fellow correctly, the decahydrate solution is approx pH 10, the octaborate solution is approx pH 8. To bring the pool back to 7.7 would simply require more acid with decahydrate than Solubor. Does this make sense, ChemGeek?
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Mar 2007
    San Rafael, CA USA
    12,082
    The key from a pH perspective is the amount of hydroxyl ions produced for the weight of the product (the Boric Acid stays mostly undissociated). The molecular weight of sodium tetraborate decahydrate (20 Mule Team Borax) is 381.3756 while the molecular weight of disodium octaborate tetrahydrate (DOT) 412.5270 so it takes 8% more weight of DOT than of Borax to produce the same pH effect (actually a little more than 8% due to the greater Boric Acid amount). I would ignore what they say about pH because I believe they are comparing the amount of product to produce a certain amount of Boric Acid and DOT produces over twice as much Boric Acid by weight as Borax. So for using this product for pH, just add a little more than you would for Borax. If you are using this product to add Borates to the pool, then you would add about half as much by weight as you would with Borax. Note that this means that you will build up Borates in your pool twice as fast using DOT compared to using Borax.
    [EDIT] I just added DOT to my spreadsheet. One pound (16 ounces weight) of Borax is equivalent to 1.17 pounds (18.75 ounces weight) of DOT for pH control. One pound of DOT is equivalent to 0.86 pounds (13.7 ounces weight) of Borax. So the accurate calculation says that it takes around 17% more weight of DOT than Borax for pH adjustment though this depends on the pH since the resulting boric acid is also a factor. [END-EDIT]
    Richard
