Up and running!
RJDriver75
11
Yorktown, VA
Just had the pool repaired and needed a full drain, so after filling back up I decided to go ahead and open since there was a ton of pollen in the pool. I think I about have it balanced. Test readings are:
FC: 4.5
CC: 0
Ph: 7.2
TA: 80
CYA: 30
CH: 120
Should I add borax to get the Ph up, which will also increase TA, or should I try aeration to raise the Ph? How long does it take to raise using aeration?
Thanks!
Mike
What form of chlorine are you using? If liquid, then I see nothing wrong with leaving the pH and TA as is and let the pH slowly rise on its own.
Posted from my Droid with Tapatalk ... sorry if my response is short ;)
