Thread: Pump Timer
    Mar 2007
    Morris, IL
    477
    Pump Timer
    I want to get a pump timer. I have a solar one, but this will only let my pump run over night for a set amount of time. What one is a good one that I could set it up to run for like two 4 hour cycles? I have plans to get a SWG to when the budget permits if it makes any difference. Although the liquidator seems cool too. [marq=right]
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2008
    Central VA
    328
    Hey Steve,
    Probably someone in the industry can answer better, but my PB is a Pentair lover, and so far the equipment is great (pump, SWG, booster pump and vac.)...He hooked me up with a Fiberstars http://www.fiberstars.com/ pool timer, which initially controlled the booster pump (if you have a vacuuum). I got some help, and now it controls the main pool pump, SWG and heat pump...anyway, it has a circle-shaped timer control broken into 15-minute segments for the 24-hour day, so you can have it on/off with really good accuracy.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator..com/
    Mar 2007
    Texas
    445
    To just start and stop the pump and not spend a lot of money? intermatic has a manual set timer , I have it and it does all that I need it to do.
    27' Round AG, 17,200 gallons, sand filter
    ThePez's Avatar
    May 2008
    Virginia Beach, VA
    26
    Quote Originally Posted by Poolidiot
    do you have a part number or link for that?
    Marc
    15x33, 13k, AGP, vinyl, 3/4 HP Pump, Sand Filter, TF-100 test kit.
    Intermatic makes many different models with a variety of features. You can look at this page to get a basic sense of what some of the options are.
    I like the PF1102T and PF1103T. They are not the least expensive models but have options that most people will want.
    Mar 2007
    Texas
    445
    Quote Originally Posted by ThePez
    Use the link that Jason has, and look at part # - T101R3 110v, metal, SPST, indoor/outdoor
