Thread: Repairing painted pipe?
    Mar 2008
    Florida
    81
    Hello all, wanted to know how you would go about fixing pipes or altering your plumbing system if its been painted. Do you simply sandpaper down to pvc? Any ideas? Just wanted to know so that in the future after finishing the build, I'll know whether or not to paint.
    Thanks
    My Pool Build
    12-15k gallons capacity, 18'x34'
    2 main drains 4 returns 1 vacuum line
    pentair intelliflo 4x160 pump 200 sq ft media filter full width (~7' wide) swimout at deep end
    pebble sheen white diamonds
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    The cleaner {primer thinner] you use before glueing the pipes will also strip the paint off, if you need to work on the pipes again. So it's not a problem, but make sure all the paint is gone where the pipes join.
    happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Mar 2007
    Morris, IL
    477
    Dittto, the primer actually melts the pipe a little bit.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2008
    Florida
    81
    Awesome, thanks for info guys.
