Results 1 to 7 of 7
Thread: How to account for this?
    Fayetteville, Arkansas
    220
    Normal readings . . . CYA of 50 . . . FC holding overnight . . . losing appx. 4ppm FC during the day? What's considered 'normal' loss in a direct sun situation? Requires appx 3 - 96 ouncers a day to bring back to target.
    20x40 30,000 gal IG Liner, Pentair II Sand
    How normal your loss is depends on what FC level you are starting at. With CYA at 50 you can expect to lose about 50% of your FC level each sunny day, a little more if the pool gets direct sunlight the entire day.
    220
    My target is 5.7 with CYA at 50.
    Losing 4 ppm from a starting point of 5.7 is not normal and suggests that something is growing in the water. It sounds like it is time to shock the pool.
    220
    Even if FC is holding overnight?
    Mar 2007
    San Rafael, CA USA
    12,085
    Holding overnight is strange when there is such a large loss during the day, but suggests that whatever is using up the chlorine may be growing during the day. So this could be a nascent algae bloom. As Jason stated, try shocking the pool and then see how things go after that. Perhaps you've got a hole in the ozone layer directly above your pool
    220
    Thanks guys . . . Aldi's Here I Come . . . woo hooo 99 cents a jug
