Pool Filler With Pictures
thall
Mar 17, 2013
10
Mississippi
I built one of those for my IG pool last year and it has worked like a charm. I spent a fair amount of time looking for an adapter to go from the NPT thread to the toilet fill thread to find that it is basically a proprietary thread and no crossovers were to be found; that's where the putty comes in. The threads from the 3/4" FNPT are close enough to "hold" the two together in order to place the putty to hold it together.
The best part is that it will only cost ~$10 and 5 minutes to replace if/when it ever fails. Much better and cheaper than the $80 pool filler that only lasts about 2 seasons of use.
Hardest part of the project....setting the water level!!!
The pool filler has been working quite well. I have moved it to a few locations around my pool to find the best location. Such a simple project i should have done years ago. No more dragging a hose out to the pool and trying to time it so the pool would not overflow. Highly recommend as a small project. :!:
