Thread: What is borate?
    Sep 2007
    middle tennessee
    38
    What is borate?
    Just wondering,,is borate level the same as PH level?..just bought some borate insta-test strips
    to add to my taylor test kit...what should my borate level read?....THANKS....
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    Apr 2008
    Indiantown, FL
    58
    Waterbear posted a great sticky on how to add borates to your pool and also the pros and cons of doing so. Here is a link to the sticky
    http://www.troublefreepool.com/viewtopi ... ht=borates
    Hope this helps,
    Eddie
    Intex 16' X 32' X 52" 14,364 galllon AGP, 16" sand filter & SWG, Pool Rover & Sunrise Journey SPA 320 gallons, TechniChlor 110 SWG
    Guest
    Re: What is borate?
    Quote Originally Posted by pooldog
    Borates are one of the chemicals we can add to a pool, often in the form of borax. Borax is often used to raise the pH when used in small amounts but large amounts of borax which is sodium tetraborate decahydrate have other positive effects on pool chemistry that are outlined in the sticky that miller9951 metioned.
    If you have not put any borates in your pool then you should have 0 ppm. If you have used borax to raise your pH you might show a trace but not much. It might not even register on the borate strip.
    If you want to add borates for all the benefits, either with borax or a commercial borate product like Proteam Supreme Plus or Poollife Endure then you want them between 30-50 ppm for a chlorine pool. 50 ppm is better.
    Sep 2007
    middle tennessee
    38
    Big THANKS for all the info.
