Results 1 to 8 of 8
Thread: ECO-SMARTE SYSTEM
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    ECO-SMARTE SYSTEM
    Chemistry Gods (Richard and Evan),
    I don't have the expertise to debunk this system though I'm pretty sure it needs debunking. Can either of you weigh in?
    Eco-Smarte
    Guest
    It's pretty much your standard copper ionizer unit. The twist the put on it is to use generated O2 as an oxidizer. O2 is NOT as effecient at O3 (ozone) because it is a stable molecule. The do recommend adding borax to the water! (Imagine that!) , They also recommend a low pH (7.2). Lower pH will help prevent staining! The main thing that works is the copper! Just an ionizer with some pseudoscience thrown in! Care to buy a magnet?
    Mar 2007
    San Rafael, CA USA
    12,082
    The non-chemical oxidation part is just splitting water into oxygen and hydrogen as follows:
    2x ( 2H2O + 2e- --> H2(g) + 2OH- )
    2H2O --> O2(g) + 4H+ + 4e-
    2H2O --> 2H2(g) + O2(g)
    and as waterbear pointed out, oxygen is not nearly as powerful an oxidizer as ozone nor as chlorine. Besides, the water should already be saturated with dissolved oxygen from being in equilibrium with the air so adding any more oxygen will probably just result in oxygen bubbles (along with the hydrogen gas bubbles) that will just float to the surface and go into the air doing, well, nothing except aerating the water causing the pH to rise. Perhaps if the salt level were high enough a little chlorine will get generated as well -- imagine that in a supposedly chlorine-free system!
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Thanks, Evan and Richard. So, O2 is a less effective oxidizer than O3 but is it effective at all? Also, while I imagine the copper can be a fairly effective algaecide, will it otherwise sanitize the water? In other words, are users of this system at risk of exposing swimmers to harmful bacteria?
    Richard,
    I don't think they advocate putting any salt in the water.
    Guest
    Quote Originally Posted by KurtV
    Richard,
    IMHO, copper is useless as a sanitizer, it's mainly an algaecide. It does have some bacteriostatic effect but it has very slow kill times so a residual of chlorine is needed for sanitation. I can't imagine how molecular oxygen would be an effective pool oxidizer. Perhaps they claim it is atomic oxygen but it would not stay in that state for very long. Unless they provide some documentation otherwise(which they don't on their website) I would have to say pseudoscience!
    Surprised they are not also including a magnet with the system and a tin foil hat!
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Evan and Richard,
    Thanks. I'll link back to this forum over on Garden Web. Hopefully your insights will save someone some money, trouble, time, etc.
    To anyone thinking about purchasing an Ecosmarte system--please refer to my post on the "Agree to Disagree--Ecosmarte" forum. RUN AWAY VERY FAST! You will have nothing but problems with Ecosmarte. Trust me, I have had the system up until this week, and as switching to SWG.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Quote Originally Posted by wrencresthome
    Well, you've come to the right place for information! Better late, than never. Be sure to check out ourSWG forum when researching your next purchase.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
