15V only gets you about 30W for your speakers, most amps are rated for a lot more than that.
JasonLion said:It is possible for non-pool transformers to short a high voltage wire to one side of the low voltage output. The lights will still work normally if it is only shorted to one side, but the results if a light gets into the pool would be extremely bad.
Pauls234 said:So, what is done to make the pool light in my return eye safe?
Yes and no. If you are specifically talking about just the exposed 12v wire, then yes. But there are many other factors that enter into it.Melt In The Sun said:So, my understanding of this is that having a 12v landscape light powered by a pool-rated transformer falling in the pool is exactly as safe as having a 12v pool light getting flooded with water...am I wrong?
