Thread: Easy Acid
    Jul 2007
    Levittown, PA
    23
    Has anyone tried Easy Acid from United Chemical. It is supposed to lower Alalinity Strongly and Lower pH only moderatedly. link http://www.poolstore.com/store1/welcome ... index.html
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    Easy Acid is just Sodium Bisulfate, the same as the usual dry acid, PH Down, PH Reducer products. It will lower TA and PH in the same proportions as muriatic acid.
    Jul 2007
    Levittown, PA
    23
    Re:
    On the package it says in contains Sodium Hydrogen Sulfate. Is this the same as Sodium Bisulfate?
    I tried it and it seemd to work in bringing down the TA without affecting the pH much. My TA came down 30ppm and my pH went down from 7. 5 to 7.2
    ____________
    Guest
    Re: Re:
    Quote Originally Posted by MrcTag
    Exactly the same as sodium bisulfate. The chemical companies do this to confuse consumers so they think that their product is different than the competitors. Bioguard does this by calling the baking soda they sell sodium hydrogen carbonate instead of sodium bicarbonate. These are just different names for the same chemical.
    A TA drop of 30 ppm with a pH drop from 7.5 to 7.2 would have happened no matter what kind of acid you used. How much the TA drops really has a lot to do with where the TA and pH are sitting initially.
    A pH drop from 7.5 to 7.2 is a significant pH drop, btw!
