In Ground Pool 17K Gal with Hot Tub
Feb 9, 2013
2
I noticed that the water level in my raised hot tub would drain down to the pool water level after a few hours. I was told it was a check valve issue. I opened the check valve and water immediately rushed up from the pipes and out the valve. I immediately put the clear plate back on to stop the water. I then found out that the water flow to the hot tub no longer works. Did I do something that requires priming? Any help would be appreciated.
Thanks
You did not happen to put the clear cover and check valve on backward did you?
Usually the pump will reprime itself in a few minutes and should push the air up to the spa ... assuming the check valve is correct.
Posted from my Droid with Tapatalk ... sorry if my response is short ;)
