Will this stuff be any good??????
DMAN11
95
Baton Rouge, LA area
Hey everybody,
It's me again, and another question for ya. We have our pool in and installer should be calling to setup time to come and install any day now...
My pool store is starting us up with some chemicals and gonna show us the ropes,,,,I guess.?.? My question is this, she is starting us up on some stuff called EZ SWIM. Anybody ever hear of this stuff? She says that it is supposed to be really easy to use. 3 to 4 scoops in the water once a week and "that's it"!! We will have an automatic chlorinator with tablets dropping about 1ppm (I think) and then this stuff. She says it has some of the other stuff mixed in (like 5 or 6 different chemicals used in the water) so I won't have to do them individually.
SO, any of you hear of this before?? And would you guys recommend staying with it????
Thanks Again........DMAN
What will you use for maintenance?
If it has 5-6 different things in it, it sounds like it may drive something... CYA.... through the roof before ya know it. along with those pucks too.
I say BBB! 8)
I believe you are referring to EZ POOL. This product has been around for a while (and under more than one name). It it a proprietary combination product that has very little info available about what is actually in it but if you go to the manufacturers webpage there is some eye opening info. Their testing procedure for the oxidizer component in it is the same as the testing procedure for a non chlorine shock (which also needs to be dosed weekly, btw) and they also make reference to testing the copper levels which implies that this product contains copper sulfate. The caution about predissolving for plaster pools adds confirmation to this.
I suspect that the oxidizer in it is NOT MPS but sodium percarbonate just from some of the things they say on thier website. Two of their other products, while they don't list the ingredients, are used in the same way as sodium percarbonate (as a shock for biguanide pools and to convert biguanide to chlorine.) They do state that the bigunaide shock is NOT MPS.
I would stay far away from this product!
Also, there is no mention of EPA registraition numbers (not suprising since they only claim the product is an oxidizier and not a sanitizer) and there seem to be NO MSDS available for any of their products.
Here is some info on it from Poolforum. Pay close attention to what PoolDoc (Ben, the administrator of PF and TRULY the Pool Guru that got us ALL on BBB!) has to say about it.
