Results 1 to 20 of 20
Thread: looking for a timer
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    looking for a timer
    I would like to have my pump and cleaner on a timer so that I don't have to run the pump all the time nor turn the cleaner on and off. The cleaner is a pressure side, Letro Platinum. I've been looking at these - http://www.pool-spa-products.com/cgi-bi ... 1208158191. Will these do what I am wanting them to do?? Which one would I need to get in order to control both? I also want the freeze protection because at this point anyway, I will not be closing my pool over this next winter.
    Thanks bunches!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Letro Legend II cleaner; Emerson 1HP pump; Pentair Boost-Rite booster pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Jun 2007
    SF Bay Area
    441
    midtngal,
    I think you will need one of these instead:
    http://www.pool-spa-products.com/cgi-bi ... 1211094515
    The device shown in your link will only run one device, and you want to run two different devices - hence you will need two separate timers as shown in the product above.
    I hope this helps. Let us know what you end up doing.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Round Rock, TX
    529
    Here is the one I use to control my two speed pump and booster pump.
    http://www.pool-spa-products.com/cgi-bi ... 1211123966
    I also bought the freeze guard sensor for it.
    They do sell them with the external case also, I just did not see it at that website.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Hmmm..thanks guys! I like the digital one. Say there's a seperate freeze timer for it?? As for the cover, I guess I will just need to get in touch with them about it.
    Thanks for the input!!
    10,700 gal IG vinyl
    2 skimmers
    Round Rock, TX
    529
    If you already have an Intermatic time, I did, you can just pull the original timer out and put the digital one in the same box.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Re: looking for a timer
    Well, I have finally gotten around to ordering this timer! I ended up getting the digital one with the freeze sensor. In talking with the guy, he says that this timer will fit into my existing breaker panel. Has everyone found this to be true?? Also, should this be something an electrician should do?? I can read instructions and I do install my own lighting and ceiling fans. Is it something more complicated than that?? TIA for any and all advice!
    10,700 gal IG vinyl
    2 skimmers
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If it's going into the existing box it should be a piece of cake. Go for it!
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    I too am looking for a timer with freeze protection. We just have the single speed pump currently, no water features, could possibly consider a heat pump but that is a few uears away. Going to install solar.
    Lights will be on another line, so I guess we are just looking at a single circuit. Our current set up is shown below. Primitive, I know, but we already owned the timer so it was the easy answer at the time.
    Question: is there some type of thermostat that we can get to work into the current set up, or would we have to get the full intermatic PF1103T? Just trying to save a few bucks.
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    amjohn, below is the sensor I ordered to go with my timer. I don't know if it will work with yours or not. You might try calling the pool and spa products folks and asking them. The guy I talked with was very helpful and friendly!
    10,700 gal IG vinyl
    2 skimmers
    You can get a freeze protection thermostat, for example the Intermatic PF1103, but it would require a separate case and costs nearly as much as the PF1103T which has freeze protection and a timer all in one.
    Apr 2008
    Central Texas
    326
    amjohn, that's one scary looking timer! What happened to the insulator that should be in front of that exposed wiring? Buy the Intermatic timer with freeze protection. The life you save may be your own... 8)
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Jason...was I told wrong?? The timer I bought has freeze protection built in, but I still needed the sensor for that to work according to this guy. Is that not your understanding??
    amjohn, if you are going to get another timer, I would go ahead and get this digital one. It's a little cheaper actually and from what this guy says, the 1102 and 1202 have to have software upgrades since they are older. It can't hurt to be ready for any new additions you may want to make in the future!
    Now, I'm just passing along what I was told. If any of this is not correct, I'd love to know that!
    Karen
    10,700 gal IG vinyl
    2 skimmers
    Sorry, I am mixing up answers to midtngal and amjohn. My previous post was in response to amjohn. amjohn's timer does not have a freeze sensor option.
    midtngal, you didn't say which model you are getting, but it is completely possible that it is the kind that works with an external sensor such as the one you posted a picture of.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    It's this one Jason - http://www.pool-spa-products.com/cgi-bi ... 1211123966. When I checked it out on Intermatic's web site, it states that it has freeze protection. But, it's a little misleading in my opinion that it doesn't tell you that you have to have the sensor for it to work!
    BTW, amjohn...this sensor runs around $40 I was told. I'll know for sure when I get it and will let you know.
    10,700 gal IG vinyl
    2 skimmers
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    H3: yes I know, scary. It's what's known as a "red-neck" timer- so that tells you something about my husband. We are definitely replacing it with something like the PF1103T as soon as we can get one. This one is about 15 years old, but it was what we had on hand for a short term solution.
    Unfortunately, as nice as the programmable one is, we are on rural electric, which cuts in and out, up and down. So every programmable device in the house has to have a surge protector AND a power conditioner on it to survive- we found that out the hard way with a computer- twice.
    We have to use mechanical switches on everything, so that is why I am looking at the mechanical models. We don't have a spa, water features, heater, or anything like that. May possibly go with a heat pump some day, but that is probably several years down the line. Starting with solar first- no power requirements there. Lights and speakers will be on the other side of the pool from the pump on a separate circuit and will only be on when we are in the pool.
    Is there anything else that I should be considering as a possible need for timer?
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Well, I have received the timer. It does come with it's own panel box and the sensor looks like it was around $50. In looking through the instructions and the equipment, I believe I have come to the conclusion that this is a project that cash was made for!!
    I have put a call in to my trusty electrician!
    Karen
    10,700 gal IG vinyl
    2 skimmers
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Waiting for mine- I went with the PF1103T- I called and they said that it came in a case and that it did not require a separate sensor like the electronic versions.
    Glad you got yours midtngal, as they are not very good at answering e-mail, and I am still waiting for some confirmation that mine has shipped.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Oh good...glad to hear you are replacing yours! No, they don't answer email it doesn't appear. I gave my order over the phone and never got any type of confirmation, but I received it 6 days later (to give you an idea).
    10,700 gal IG vinyl
    2 skimmers
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Thanks- mine came today. The surprise bonus- not only is the cover there and the temp probe built in (though we will have to extend it out in a tube installation), but the timer can turn off and on up to 8 different times a day- seriously doubt we would use that, but it was surprising. My husband still needs to look at the wiring, but it looks pretty straight forward.
  20. Back To Top    #20
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Re: looking for help on wiring my timer
    I have an electrician here wiring in the timer from above posts and he is a little perplexed. He's confused as to why there is only one line and one load connect per circuit. He says there should be 2 unless he is supposed to "break one of the legs".... Does anyone know the answer to this or is there a trick to having this installed??
    Thanks much!
    10,700 gal IG vinyl
    2 skimmers
