Pool being replastered - bond coat got wet
Jun 18, 2010
61
Arlington, TX
CircuPool RJ-60 Plus
Hi,
I'm having my pool replastered and today they did all of the prep work. They drained the pool, acid washed, and bond coated. When I got home from work tonight, my timer had turned on my pool pumps (both the filter pump and polaris pump). The pumps ran for just over an hour. Now there is a decent amount of water at the bottom of the pool, and you can see where the water ran down from returns to the drain (pic below). At least the pumps weren't running completely dry... Should I be concerned that the bond coat is wet? How long should it have been allowed to remain completely dry?
Tomorrow they are coming out to start applying the new plaster. I plan on being here to talk this over with them. I figured I would see what I could find out before then.
