Pump parts
Jul 21, 2012
23
I have a broken impeller on the pump which powers my pool cleaner. It is a Magnatek Century Centurion, Pool and Spa Duty. 3/4 HP, 240v Cat. B668. Any idea where I can find a replacement. Through Google I can find plenty of motors and parts, but no pump parts.
Thanks in advance
That is the motor information. You need the pump make and model.
http://www.zodiacpoolsystems.com/Produc ... Pumps.aspx
http://www.pentairpool.com/pool-pro/pro ... ump-17.htm
http://www.hayward-pool.com/prd/In-Grou ... 002__I.htm
I think that you probably have the Pentair/Letro. Can you find any other information on the pump, or stamped into one of the parts? You should also get a seal and a new O-ring.
http://www.pentairpool.com/pool-pro/par ... ump-16.htm
Yes, it is a booster pump. And, yes on close inspection, it is marked Letro. I just didn't look close enough before I posted. I got an impeller this morning and just got it installed.
Again, thanks for the help.
