Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Whats the best barbecue to buy?
    Jul 2007
    Fareham,England
    41
    Gas or Charcoal.
    I'm in the hunt for a new barbecue. any recomondations?
    I have never cooked on gas as it dosent seem right. I love by kettle barbecue but its starting to fall to bits was thinking of 1 of these.
    http://www.weber.com/bbq/pub/grill/2007 ... old22.aspx
    Apr 2008
    Central Texas
    326
    Weber makes some awesome stuff. We prefer using propane, simply because it makes the process so much easier. Instead of using the grill only on the occasional weekend, we use it several times each week. Building a charcoal fire just to cook a couple of burgers is not something that we want to deal with. We have a Char-Broil Commercial Series gas grill and love it.
    Also, the current issue of Consumer Reports tests lots of different propane grills.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Jul 2007
    Fareham,England
    41
    whats the taste like from Gas?
    is it as nice?
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    You can't go wrong with Weber. As far as gas or charcoal, it's all a mater of taste. Most people prefer the taste of cooking over charcoal or wood, but some foods, like steak need to be cooked over very high heat and gas is ideal for that. Gas is obviously more convenient as well.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jul 2007
    Fareham,England
    41
    is the Kettle barbecue the way to go?
    I have friends from Zimbabwe that only cook in Big Oil drums and pour beer over the flames (seems a waste of beer to me)
    They do cook like Half a pig at a time..LOL
    I live in the UK and Barbecues are Exciting to us over hear (Only time the man does the cooking)LOL
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    With a charcoal chimney, I can get a charcoal grill ready in the same time my napoleon gas unit takes to warm up. True, there is more maintenance to a charcoal grill, and more cleanup, but that means more beer drinking time. I like the convenience of having both. Its easier to cook in the rain on the gas unit.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Richardson, TX
    287
    I've got the older version of this: http://www.academy.com/index.php?page=c ... 02219-3361
    The only difference i can see in mine and this unit is the pull out ash pan on the smoker side.
    I use it for a grill all the time in the larger kettle side, a bit of a pain to clean all the ashes out but I can usually grill three or four times before I have to clean it out.
    Also, it works awesome as a smoker! I've done pounds and pounds of pulled pork, brisket, fish, etc...
    I call it my 2 in 1
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Guest
    I gave up on charcoal a long time ago for the convenience of gas. If I want a wood taste (without the charcoal starter taste!) in my food I put some moistened wood chips in a smoker box in the grill and l close the grill lid. I prefer the mesquite chips. If you don't have a smoker box you can just wrap the damp chips in aluminum foil, poke some holes in the foil, and place it on the grill.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I love to grill so I bought the Weber Summit Platinum. This thing is awesome! It has a side mounted burner and a smoker. It cooks perfectly everytime. Also Webers customer service is top notch. I had a low end Weber before and it got picked up by the wind and thrown off my deck. At the time I couldn't buy a new one so I called Weber to buy parts and they sent me out brand new ones without even charging me. It was clearly out of warranty but they were so cool about it. I say Weber all the way!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    SeanB's Avatar
    Mar 2007
    2,622
    The wood chips work pretty good on a gas grill to add a little extra flavor. I think a wood plank might do even better, though I've never used one.
    If you use charcoal and your food tastes like lighter fluid, then you are not letting the coals burn long enough before putting on your food.
    TFP Founder
    gonefishin's Avatar
    Joliet, Il.
    399
    Quote Originally Posted by SeanB
    I'd certainly agree with that. If you're using lighter fluid, be sure to let the coals get good and hot before putting your food on the the grill. You can also use an alternative such as the charcoal chimney(mentioned above) or a blowtorch on the coal pile. I use my MAPP gas blowtorch with good results.
    happy grill hunting!
    dan
    21' Aqua-Leader AGP (10,200 gallons).
    Hayward cartridge filter and two speed pump.
    Aqua-Cal HeatWave 100k (HeatPump)
    Salt 3200ppm (in non-salt water pool)
    Borates 20ppm (slowly raising)
    Aqua-Rite SWG
    Mar 2007
    Texas
    441
    Quote Originally Posted by waterbear
    I am just starting to get into BBQing, I will have to remember this 8)
    27' Round AG, 17,200 gallons, sand filter
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Yeah thats pretty crafty waterbear, my smoker box upgrade was 150$ when I bought my grill. Wish I had known that before. The lighter fluid taste is a huge issue with grilling. Although I agree when you have the time to grill properly it is a better taste but actually studies show cooking with gas is safer due to the carcinogens being released during grilling over coals. But I sure do loooove the taste of those carcinogens
    SeanB's Avatar
    Mar 2007
    2,622
    Just drink a glass of O.J. afterwards and you'll take care of all those free radicals.
    TFP Founder
    Richardson, TX
    287
    I've never used lighter fluid, we go through one or two of these a season (yes, I bbq A LOT) they work great, throw a pile of charcoal on them, plug in, 15 minutes perfect flame, 10/15 more and perfect for grilling! I also use it to start the smoker, get some lump charcoal, put a couple of pieces of wood in there, plug in...done!
    https://www.hardwareworld.com/Electric- ... NHAQH.aspx
    You can get them at Lowes not sure about home depot or wal-mart, been over 7 years since I've ever shoped at either. Lowes and Target always has everything we need, their closer and better customer service!
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I use gas for grilling. I like the taste of food cooked over charcoal, but like even better the convenience that gas provides. I also use gas fired smokers, but use some charcoal with them for flavor and for igniting the smoke wood. Now that I think about it, I guess you could use a couple of charcoal briquets with a gas grill for flavor as well. I'll have to try that, next time I throw some burgers on.
    Best way I've found to light off a chimney of charcoal is to put 5 or 6 of the instant light briquets in the bottom of the chimney, and then finish filling up the chimney with regular briquets. Word of warning - whatever you do, do not use only instant light briquets with a charcoal chimney!! Your chimney will look like the business end of a jet engine! (Don't ask me how I know this.. )
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Round Rock, TX
    525
    My recommendation is to buy something that you will use. If your new to it all, buy something that is easy and convenient. That probably means gas or electric. If you find you really like it and want to invest more time into it then you can move to something charcoal related.
    You can make very good BBQ on any of them.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    SeanB's Avatar
    Mar 2007
    2,622
    I'm shopping for a new smoker. My starter model is starting to burn out on the firebox already. It gets the job done, but it doesn't hold the heat well which makes it tought to keep a consistant temperature.
    I'll be buying a much better one this time.
    TFP Founder
    Feb 2008
    Denton, TX
    5,061
    The better grills can be purchased at those BBQ specialty stores like Barbeques Galore. We bought a Barbeques Galore Captain Cook model 12 years ago and it still works great. Certainly not even close to their top model but excellent nonetheless. They are a little more pricey than going and getting a grill from Lowe's but their stuff will last longer and when things wear out and need replacing, you can always get them right again because they have all the parts available.
    One thing to consider if you have natural gas is to have a gas jet installed outside. We did this on a new construction home previously and it is the greatest thing ever to not have to worry about ever running out of gas in the middle of a cookout. Any decent gas grill can be fitted with a simple conversion kit to go from propane to regular natural gas. You switch out the flex line and the Venturi nuts (NG requires larger lumen "holes") and that is that.
    Now for a real opinion and it is just my $0.02, but when I do steaks, I only do them on charcoal. It's a taste thing. I've tried adding wood chips and all that jazz for the gas grill and it just isn't as good as the flavor you get with charcoal no matter what anyone says. For that reason, I still have an old Weber kettle out back for steaks. If I remember, whenever I go out to the ranch, I try to bring back some mesquite wood. Lighting that stuff up in the Weber and letting it burn down into coal is just the BEST for steaks.
    Craig
  20. Back To Top    #20
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Sean,
    I saw an ad for an Orion OC-1 smoker in my last issue of Popular Mechanics. They sell them at Home Depot for about $140, they're charcoal fired, made of stainless steel, and supposedly create a convection cooking chamber by placing hot coals around the base and in the chimney of the unit. Here's the link to the manufacturer's website:
    linky
    I was sorely tempted to get one, but the DW reminded me that I have three smokers already, and don't have room for a fourth. Hmmm...maybe I need to let one sit in the rain and rust out too...
    Edit: Oops! It wasn't an ad, it was a test drive by the PM staff. There's a .pdf of the article on the website as well.
    Intex 8110 SWCG
    "Fear the Schnauz!"
