Finished self install have test results NOW WHAT??
4knights
430
NE Kansas
Salt 3010
CYA 55
FC. 0.5
TA. 250
PH. 7.2
CH 270
Water temp 63*
Using the TF-100 with the lighted battery mixer and salt test stick want to balance the water before I bring to closure levels and close for the winter. Sad to sit on the deck knowing its finally done but y to cold to get in.
So, in what order do I add/subtract items?
My SCG is running at 60%
CYA is a bit low for SWG ... although may not matter as much in the winter.
Get the FC up immediately with bleach and then let the SWG maintain it.
You are going to have to watch the pH as it will likely rise fast due to the SWG and the high TA ... you may eventually want to work on lowering the TA (see Pool School article).
