Ok to drain this chem mix into plants?
bobhatfield
30
Phoenix, Arizona USA
Pentair Intellichlor IC-40
Need to drain 20% of my pool. Ok to water plants with this? In dry Phoenix where plants could use.
TF-100 test kit:
FC 0.5
CC 0
TC 0.5
TA 170
CH 800
CYA 100+
K-1000 basic test kit:
pH 7.8
Lawns can tolerate more than some plants. It's mostly the salt level (sodium chloride) that is an issue (and boron can be an issue, but it sounds like you don't have borates in your pool water). You have high calcium so probably have high chloride as well. Probably not as high as a salt pool. Probably OK for lawns and sturdier plants, but delicate plants might not like it and you should water them with your regular sprinkling system to dilute the pool water, if you end up using that.
